How are these welds?
发表于 2021-8-31 23:38:30 | 显示全部楼层 |阅读模式
Just got my Miller 211 Mig Welder.. its the bomb!  Autoset works nice!Anyways, I'm not a welder, I used to do it ocassionally about 10 years ago, when I was working as a Tool and Die Maker...  These are some of the welds I did while making a little project..Can you plz look at them and tell me if they are decent and / or what I can do to make them right.  (heat, speed, wire etc)Thanks! Attached Images
Reply:Looks ok, but stripping the scale is very much recommended.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Looks good. I think a smidgen more heat and faster travel would help flatten the welds out. Clean the steel really good and keep your gun angle. Looks real good though. Keep it up. Thanks for reading!
Reply:I'm loving my 211 as well!
Reply:Those welds will work!! IMO I prefer not to use the autoset on the new welders I dont think they have enough heat into the welds. I think they lay the weld on the metal instead of getting penetration? Iam old school tho..Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:Don't need to abbreviate please, as PLZ.  Just sayin.  Looks like you've picked it back up nicely.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Thnx for the replies!  Think ill play with the settings tomorrow    See how I make out without the auto set
Reply:Yrwlcom!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by rabidchimpDon't need to abbreviate please, as PLZ.  Just sayin.  Looks like you've picked it back up nicely.-Aaron
GMT+8, 2025-12-25 20:53 , Processed in 0.115655 second(s), 18 queries .
