stump grinder
发表于 2021-8-31 23:38:30 | 显示全部楼层 |阅读模式
I am going to build a small stump grinder with a yanmar L100 diesel engine. any info on building the head would be help full and the drive thanks i am not sure if i should use a belt drive or chain thanks
Reply:Belts may absorb the shock loads better. I might find a factory machine and do a thorough nosing around it to see how its put together.
Reply:what about using the wheel bearing and flange off a front wheel drive car. take the end of the cv shaft and weld a double sheeve pulley onto the tulip then build brackets and a toothed wheel
Reply:i like that idea i think it would work great i will see how it goes
GMT+8, 2025-12-25 20:29 , Processed in 0.204131 second(s), 18 queries .
