Steel gazebo
发表于 2021-8-31 23:38:29 | 显示全部楼层 |阅读模式
Hey all, I wanted to share my project that took forever.Structure is mostly square tubing, and with all parts bolting together so it can be moved. Attached ImagesMy adventures in welding projects:http://weldingshopblog.blogspot.com/
Reply:A couple more. I had to make this boom attachment for the tractor front end loader to avoid hiring a crane or something else to get the roof lifted in place. Attached ImagesMy adventures in welding projects:http://weldingshopblog.blogspot.com/
Reply:Nice, I bet that thing is heavy. What did you do to secure that arm to your front loader?
Reply:Beautiful design and fine workmanship.  I'll bet that gazebo weighs a ton (or more).Miller 211 w/ spool gunMiller Dynasty 200DXLongevity 60i IGBT plasmaO/A w/ crappy chinese torch/gaugesSouth Bend 10K latheGrizzly 4029 10x54 millGrizzly 7x12 hor bandsawangle grnders, bench grnder, bench belt sndr7.5 hp 80gal cmprsor
Reply:Great. Lots of work there. Looks perfect. I see that little silo in the back ground and think I'd probably just set one of those up and cut some windows in there, call 'er good for the day. "The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Thanks all, I secured the boom to the loaded with a piece of steel channel and four 3/4" bolts. I also had three "guy chains" connected at the end of the boom to the bucket. Probably was overkill...My adventures in welding projects:http://weldingshopblog.blogspot.com/
GMT+8, 2025-12-25 20:53 , Processed in 0.120821 second(s), 18 queries .
