Simple 4x6 Bandsaw Stand
发表于 2021-8-31 23:38:28 | 显示全部楼层 |阅读模式
One of the guys I share a shop with wanted a stand for his 4x6 bandsaw.He wanted the saw to be more stable and easy to roll around ( we have a small shop).He also didn't want to spend as much as I did on my bandsaw base. http://weldingweb.com/vbb/showthread.php?t=53951The factory base on his saw was in pretty good shape so I decided just to build a frame and add casters.I used 1-1/2 " angle, and made the frame 3" longer than the base. I made the feet 2" wider on each side and used casters with treaded stems. My local caster supplier had some casters that someone ordered and didn't pick up so I got them pretty cheap.I bolted the saw to the base and it made everything really rigid.It came out pretty well, it's very steady when used as a vertical saw with all 4 wheels locked.It also raised the saw up about 4" so it's easier on the back.Last edited by CamW; 04-29-2011 at 02:19 PM.
Reply:nice simple stand!! i like itAdam MMorales Ranch
Reply:Nice job!(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
GMT+8, 2025-12-25 20:39 , Processed in 0.187685 second(s), 18 queries .
