follow up ? to cutting culvert underwater ? of April 28
发表于 2021-8-31 23:38:28 | 显示全部楼层 |阅读模式
I posted a question April 28, 2011 about cutting off a culvert that was all under water.Some one suggested using an oxyaceline tourch to do it, and the water can not be drained off or pumped down/out of the pond. See photo at other post.Does any one have suggestions on how to do this.Does the inside of the culvert have to completely dry, free of water?How much water can be on the bottom of the culvert and the tourch still cut the galvanized steel metal.Are there any fumes from the galvanized metal being cut I should be concerned with?How much heat do I need to apply to the steel metal before applying oxygen to the cut?What should the flame at the end of the tourch look like to cut under water?Any special cutting tourch head I should use?Any other comments would be appreciated.
Reply:Check Pm's.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:"Are there any fumes from the galvanized metal being cut I should be concerned with?How much heat do I need to apply to the steel metal before applying oxygen to the cut?What should the flame at the end of the tourch look like to cut under water?Any special cutting tourch head I should use?Any other comments would be appreciated."No offense, but these questions make me concerned for your safety. Galvanized will produce toxic fumes. You need a respirator with APPROPRIATE filters....http://www.westernsafety.com/newnort...newnorth1.html200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:yes, if you suck on the zinc fumes long enough, about 5 hours later you will get hammered with flu like fever, nausea, body aches and chills. It sucks.Weldanpower 225 G7Ironworkers Local #24
GMT+8, 2025-12-25 20:31 , Processed in 0.091831 second(s), 18 queries .
