Just thinking ? The reason for a rod oven is to remove moisture.Why wouldn't Desiccant Beads work with out the waste of energy.I know it's been thought of just looking for the why?
Reply:the beads absorb moisture in the air. the rod oven bakes the moisture out of the flux that has been absorbed into it. quite a few folks will drop the silica gel beads into an airtight rod canister to keep them dry...Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Because it won't meet code.Desiccant beads only absorb so much moisture. For home use, it's better than nothing, but for code work, it won't cut it. As long as the oven is plugged in and running, it will keep the rods protected as long as they started out good. The average oven won't recondition rods however.Keep in mind many times codes are hard to change. Also many times specs will get pulled simply because there's already a "standard" that's stricter than required, and guys simply copy paste..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thank you. Now I know. |
