Where to buy welded rings?
发表于 2021-8-31 23:38:22 | 显示全部楼层 |阅读模式
Been having a hard time finding these, not wanting to roll them myself. I'm looking for welded rings in the 12"-18" diameter range, 3/16"-1/4" thick or so.  I've had no problem with small diameter rings, but my search for the larger ones is batting zero.  Would also be interested in finding thin-gauge welded rings of 1/2"-1" width somewhere.  These will be used in making a custom light fixture.Any help would be much appreciated!
Reply:You could try euro forgings?I can weld anything but the crack of dawn! www.schwartzwelding.comwww.facebook.com/schwartz.inc
Reply:Biggest I was able to find with EF was 8" diameter.
Reply:Can you cut the rings from pipe the diameter you need?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Don't have anything in that size.  Unfortunately, I had an online source that was selling them to make dream catchers from at a few bucks a piece, but have since stopped carrying them.
Reply:kings architecual or Mcmaster carr
Reply:Unfortunately, neither had anything bigger than 8 inches or so.
Reply:My company specializes in making rings.  We can make any size welded rings from 1/32" ID to 30" ID.   I have 1/4" 304 wire in stock - rings in the 8-12 inch range cost about $3 each - plasma welded and polished.email me at jd at theringlord.com
Reply:http://steel.kingmetals.com/search?p...etalsteelringsDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Thin gauge and wire rings can be quickly made with bandsaw blade welder.Dynasty 300DXSmith He/Ar gas mixerMM350PHobart Handler 120Smith LW7, MW5, AW1A
GMT+8, 2025-12-25 20:51 , Processed in 0.100684 second(s), 18 queries .
