Excaliber 7018-1
发表于 2021-8-31 23:38:15 | 显示全部楼层 |阅读模式
I prefer the excaliber and the Lincoln rep told me that the -1 has better stacking properties for uphill and overhead type work.  He said that pipe welders are really liking it.I was wondering if anyone has used it and what you think.
Reply:i;m a pipe welder and i preffer atom arc by esab, 7018 is an all position rod anywaymember of plumbers and pipefitters local 630 lincoln 130 inverter1965 red face sa 200
Reply:Both the Atomic Arc and the Excalibur are really nice running rods especially for vert up work.  I like the way the metal flows smoothly to fill the groove.
Reply:Third vote for Atom arc....   and -1 is my fav no matter what brand.My name's not Jim....
Reply:The Excalibur has a less smokey flux so you are able to see better but the metal does not lay as nice as the Esab. The Esab is a little harder to see but I like it way better until I get to the very top of the pipe, at which point I struggle to see the weld pool through all the smoke.UA Local 598
Reply:Work has been buying 2 rods for carbon steel pipe welding for some time now. ESAB OK 55 7018 and Air Liquid blueshield 7018. I like both of them.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I really like Excaliber 7018MR
GMT+8, 2025-12-25 20:30 , Processed in 0.072097 second(s), 18 queries .
