Which Welder
发表于 2021-8-31 23:38:14 | 显示全部楼层 |阅读模式
HiI am a complete Novice when it comes to TIG Aluminium welding (Actually TIG)I have searched for a welder with the qualities I think i Need & have narrowed it to 4 units (Available at a reasonable Price in Australia).I was hopeing some on this Forum could give me A helping Hand in Choosing oneIt will only be used for home use/& hobbies But its cheeper to buy & learn than spending $250.00 an hour to have small jobs done here by a jobbing shop.All are AC/DC & some have a 1 year & others 5 years warrantee.Contenders areACDC200PMhttp://www.tokentools.com.au/prod77.htmFeaturesPlant Contents – Alupulse 200• MOSFET inverter welder power drive matrix• ACDC200PM - 200 Amp TIG MMA Welder• Easy to use digital display and panel control• 4 metre ergonomic 26 series TIG Torch• Pulse frequency control to 300hz• 3 metre earth cable and clamp• HF start TIG & MMAW modes• 3 metre MMA cable and holder• 2T, 4T repeat function• 3 metre gas line• Intelligent self diagnostic protection• TIG accessory kit• High duty cycle 200A 60% @ 40 Degrees C• Instruction manual• Up and down slope controls • Arc force control • Post flow control• Individual base and pulse amps control • Parametric pulse control system • Presettable amperage indicator • TIG accessory kit • Rugged protective caseEverlast Power TIG 185 Microhttp://www.everlastwelds.com.au/weld...185_Micro.html Features & BenefitsEasy low amp 5 amp start DC, 20 amp AC.Compact inverter design makes it one of the lightest and smallest in its classSimple, yet fully functional controls allow any user to make high quality welds.Smooth stable arc in DC or AC with excellent wet in.Automatic preflow and post flow keep operation parameters simple by offering a preset timing of flow.Digital readout for precise control of welding amps in 2T mode.2T or Foot pedal operation gives operator choices in out of position welding situations.DINSE 25 style connectors allow easy adaptation of aftermarket torches.Suitable for use with any 4500 watt "clean power" generator.Rossi 4 in 1 Inverter Welder TIG/Cuts/Welds/ACDChttp://www.agrmachinery.com.au/buy/r...LD-ROSSI-205TCTIG: 10-200AmpsMMA: 10-160AmpsPlasma Cutter: 20-40AmpsPulse Frequency: 0.5-25HzPulse Width: 10%-90%AC Balance: 30%-70%Base Current Ratio: 5-100%Open Circuit Votage: 60-80VTIG Duty Cycle: 60%@200AmpsMMA Duty Cycle: 35%@160AmpsEfficiency: Greater than 83%Arc Striking: HF Ignition CircuitAC Welding Frequency: 20-100HzCut Clean: 12mm (Max)Cut Severance: 16mm (Max)Plasma Duty Cycle: 60%@40AmpsPlasma Cutter Type: ContactProtection Class: IP21SCooling: 1x200mm Fan ForcedWeight: 26kgsSize: 510mm x 215mm x 345mmWeldSmart 185 Amp Ac/Dc Tig & MMA Inverter Welderhttp://quokka.com.au/listing/6139/Features:Form Factor: All new European designed shape for ruggedness & durabilityBody: All new body ensures stability under all circumstancesSloped Panel: All new sloped panel ensures simple viewing & quick accessibilitySingle Phase 240V: Industrial power run off single phaseToshiba Inverter based power source: Optimal arc performance and High duty cyclesCompact and lightweight: Adds simple portability for off site jobsGenerator Safe: Perfect for off site jobs running on a generatorMultifunction: Tig Ac/Dc, Tig Dc, Stick/MMADigital Display: Easy to view welding amperageExtended Ac Balance Control: Adjust the balance between penetration and cleaning for AluminiumDown Slope: Slope down the amperage to prevent crater crackingPost Flow: Prevent oxidation of weld metal by post gas flow2T & 4T Trigger Latching: Use when welding for long periods of timeAdvanced Square wave: Improves weldability with excellent puddle controlHigh Frequency Start: Non-Contact Tig arc startingTig Welds all Metals: Tig weld almost any ferrous and non-ferrous metal known to manMMA Welding: MMA weld from basic electrodes all the way through low hydrogenSo if anyone would like to assist in a selection it would be gratefully acceptedThanks in Advance for your inputs
Reply:I have no idea, but I will tell you, that based on what you read on here you can probably cross the everlast off your list. Some are good and some are bad, but if you have to ship that thing back over seas to the states or wherever to fix it; it's probably going to take awhile and cost a lot. They don't have good customer service. Unless they are local to you, which I have no idea.Did you look at the one from eastwood? It's a reputable company so I'm sure they will ship it, just not sure how much.Did you also look around for a used one locally?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:All I am willing to say about those listed is avoid multifunction welder/cutters.If you are truly trying to save the expense of hiring a professional, at least try to buy professional quality machinery. That means going to your local welding supply and getting a demo on something they carry and support. With the right equipment and support you could become very proficient and save thousands not hundreds.Good luck and don't let the giant rabbits bite.Last edited by shovelon; 01-18-2013 at 01:30 AM.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:It's been a while, but I seem to recall lots of issues with MOFSET based units in the past. I think many of the imports moved away from MOFSETS and towards IGBT based machines. I'll let the electronics expets comment more on this. Originally Posted by shovelonIf you are truly trying to save the expense of hiring a professional, at least try to buy professional quality machinery. That means going to your local welding supply and getting a demo on something they carry and support. With the right equipment and support you could become very proficient and save thousands not hundreds.
Reply:Originally Posted by GambleI have no idea, but I will tell you, that based on what you read on here you can probably cross the everlast off your list. Some are good and some are bad, but if you have to ship that thing back over seas to the states or wherever to fix it; it's probably going to take awhile and cost a lot. They don't have good customer service. Unless they are local to you, which I have no idea.Did you look at the one from eastwood? It's a reputable company so I'm sure they will ship it, just not sure how much.Did you also look around for a used one locally?
GMT+8, 2025-12-25 20:32 , Processed in 0.097971 second(s), 18 queries .
