Bolting a Bobcat 225 to my truck?
发表于 2021-8-31 23:38:12 | 显示全部楼层 |阅读模式
So i'm getting ready to do some small jobs while i'm in welding school, i've got a Miller Bobcat 225 and I'm wondering if I should build a frame and bolt it down on my '03 F350 Dually or just let it sit loose in the bed?"Firearms stand next in importance to the Constitution itself. They are the American people's Liberty, Teeth, and Keystone under Independence." - George Washington
Reply:bolt it down, lest you get in a wreck and it tries to come thru the back window like happened to me. 3 weeks after I put my machine in a cow walked out in the highway and I hit it doing 65.
Reply:If you don't bolt it down, sooner or later you will need to make a sudden change in direction and your welder will flip over. Loose welders have also been known to vanish in the night if not well secured. They sometimes do anyway. Secure your Bobcat to your truck as solidly as you can.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:We got one at work that had a retainer bar holding it in a service truck.Truck rolled, welder cases took a beating when it flew out.Insurance company totaled it.I won't give much for it because in my opinion, you don't know what happened to the engine/gen.Bolt it down and keep it from walking away at night.
Reply:You guys must live in some upscale neighborhoods, Alot of the places I work in , they don't wait for night time. LOL"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Yes bolt it down. thieves know those small machines only  weigh a couple hundred pounds.  my ranger 8 walked away from a parking lot off bourbon street during the day too.58 sa 200 code 355581 sa 20093 big blue 251dBobcat 225millermatic 210Hobart cybertigHypertherm 1250Lazy a** blue pit
Reply:Maybe even go so far as to put a small tack on a couple of the more accessible bolts.  If they want the welder bad enough they may go to the trouble of trying to unbolt it.  A couple of small tacks could easily be ground off if you needed to move the Bobcat for any reason.  And,...if they tried to use a socket for quick bolt/nut removal, the tack would keep them from seating the socket.  I doubt any thieves would take the time or risk making the noise to remove the tacks.
Reply:Would I mount just drill into the bed and mount it that way?"Firearms stand next in importance to the Constitution itself. They are the American people's Liberty, Teeth, and Keystone under Independence." - George Washington
Reply:Originally Posted by Jeromy_EWould I mount just drill into the bed and mount it that way?
Reply:Originally Posted by kolotYou guys must live in some upscale neighborhoods, Alot of the places I work in , they don't wait for night time. LOL
Reply:You could always bulid a welding skid that way you have other tools like your O/A cutting rig or a argon bottle and you still have your full size bed. And you want have to worry about leavening it in a parking lot or something like that. But if you decided to bolt it make sure you bolt it to your frame maybe use look tight or weld the nut .  Maybe talk to your insurence company and see if they will cover your welding machine along with your other tools. Hope I helpedMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
GMT+8, 2025-12-25 20:33 , Processed in 0.150433 second(s), 18 queries .
