Lincoln Magnum 100sg Questions
发表于 2021-8-31 23:38:03 | 显示全部楼层 |阅读模式
Looking to try a few projects in Aluminum and saw one of these on sale. Anyone using it or the Miller type with a 140 Machine? Do you like it? Was it worth it? Did you wish you didn't buy and put the money towards a TIG instead?? Thoughts???Thanks,Dave
Reply:A 140 is way under powered for running a spool gunVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by DualieA 140 is way under powered for running a spool gun
Reply:Personally i wouldn't bother with it on anything less than a 230.  but i have heard of guys making it work on a 180.   Aluminum is really out of the practice range of a 110V mig.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Thanks Dualie!Dave
GMT+8, 2025-12-25 20:52 , Processed in 0.207325 second(s), 18 queries .
