New tig on the way
发表于 2021-8-31 23:38:03 | 显示全部楼层 |阅读模式
I struck a deal with the LWS here in Dubuque and have a Presion Tig 225 on the way. I already has a bottle of gas. So what else should I get when I pick it up so I can play around with it. I'm have no idea on what is a good stainless rod and the same with alum. What tunstion should I have also. I just need a basic starter kit idea and as time and cash permit I will get more. Thanks for any idea's. I will also be getting a stinger so I can stick weld the larger items.]Lincoln PT 225 Tig
Reply:Ceriated or lanthinated tungsten; ER308 is good for most 300 series stainless (a lot of guys like 309 also), ER70S2 is good for a variety of steels, and 4043 is a good (fairly universal) alum. filler.Have fun with it."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:it should come with a torch and stinger. Get some 6010, 7018, er70s2 and start there.UA Local 598
Reply:Thanks for the tips. What is the difference between the 6010 and 6011? Also what size in the tungston should I get?]Lincoln PT 225 Tig
Reply:Originally Posted by DrichWhat is the difference between the 6010 and 6011?
Reply:Drich,      Just get the 6010, 6011 is for AC.  If you had to buy one size to start it would be 3/32" the choice of flavor is up to you.
GMT+8, 2025-12-25 20:50 , Processed in 0.093367 second(s), 18 queries .
