red seal journyman ticket?
发表于 2021-8-31 23:38:01 | 显示全部楼层 |阅读模式
I have been doing a little research on this. Do any of you guts have or know where i can get the practice written test? I wanna see how far off i am of obtaining this stamp. I have my cwb in fcaw all positions. Thanks guys for any info
Reply:Dept of labour in these parts.(Eastern Canada)
Reply:I have my red seal but i Didn't do a practice one, i thought it wasn't to bad.
Reply:Weldr11 what were the test on? Is just math,layouts,weld symbols? Thanks for the info im really interested in getting this so i can have a shot at a job in fort mcury, A.B for joy global.
Reply:It used to be it cost $100 to get Red Seal info and practice tests.  Now there's quite a bit online.  A sample here.....http://tradesecrets.alberta.ca/SOURC...acticeExam.pdf
Reply:You can get the Red Seal books from the CWB website, I believe that is the only place you can get them. There are really good books with lots of good info.Its really not that hard of a test, the one online is was quite close to the one I wrote. They did have some questions about plate prep, rigging, all the welding procceses and so on. If you go on the Red Seal trades web site you will find a breakdown of what the test covers.My local welding school set up the test for me which was free of charge.I believe you need a minimum of 5400 hrs of recorded welding time in your log book to write the test.Last edited by Biggerair; 01-17-2013 at 04:40 PM.Reason: more info
Reply:http://trades.exambank.com/welding.htmlGonna cost you a bit to take them but it's worth it. For $50 you could access 5 tests of 120 random questions (how many are on the actual test) selected out of a bank 1707 question (there are some which are similar--reproduced for a different year with slightly different data). This will give you a very good idea of what you'll likely get on the test.If you're interested click "How to get an account". In my experience they are a little tougher than the questions in the back of the apprenticeship manuals and about on-par with the actual test.Last edited by Rora; 01-22-2013 at 03:07 PM.
Reply:I took the test this past spring,  thought it was stupid and easy passed with ease....  lots on submerged arc and gouging...  and some on plasma cutting...Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
GMT+8, 2025-12-25 19:11 , Processed in 0.090710 second(s), 18 queries .
