Ultralite Gas Tank
发表于 2021-8-31 23:37:56 | 显示全部楼层 |阅读模式
This is an Alum ultra lite gas tank, It was riveted together welded, then the pins were removed from the rivets and the rivets were welded. There was no finish work done to it the guy liked the way it looked with the welded rivets showing.
GMT+8, 2025-12-25 19:11 , Processed in 0.077299 second(s), 18 queries .
