License plates
发表于 2021-8-31 23:37:55 | 显示全部楼层 |阅读模式
I have never welded anything in my life, but want to learn how to weld license plates together for a project.  Should I use a torch or a MIG (TIG too expensive)?  Or is there a better option?  I'm leaning towards MIG with high volt since they are very thin gauge and aluminum.
Reply:Is this the only time you're going to be welding?  Mig with aluminum that thin might be a problem.  And a Tig machine is expensive.There are 3m structural adhesives that would to the trick for a lot less money than buying a welder.  Properly applied, the aluminum will tear before the adhesive bond fails.Can you describe the kind of use (or specific stresses) the joined plates will be subjected to?Jack OlsenMy garage website
Reply:What are license plates made of, aluminum?  TIG may still be an option if you rent one.  I would think MIG would handle it fine as long as you not using flux.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Thanks, pretty much zero stress as they are just pieces being welded together then hung on the wall.
GMT+8, 2025-12-25 19:11 , Processed in 0.068358 second(s), 18 queries .
