sizing argon acetylene bottles
发表于 2021-8-31 23:37:55 | 显示全部楼层 |阅读模式
this sounds dumb even to me but i havent ever been able to figure this outthere are different sizes of ox acet argon helium whatever gas containers..how do you know the cubic foot size of the bottle.somehwere in that mess of numbers on the top it must tell you the size.in order to order a cart or mtg brackets w/o measuring the od of the bottlethanksgary
Reply:A quick search gets you HERE!It depends on the type of gas, as well as the cylinder dimensions.  Lots of references in the thread...........
Reply:Typically, for gases other than acetylene, the small 8" dia bottles go from 40cf, 60, 80, 125 and 150.  The bigger 9" dia bottles go from 200-330cf.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:There are ICC1800, 2015 and 2400 on the top of the cylinder.  JGSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:good question deislbeef. i have ox bottle that my techair guy says is 135 cf..if you calculate the bottle it is about 8.5 inch id x a little over 4 feet high..that is around 1.35 cf.....the numbers on top to my knowledge are the test dates...
Reply:yah..w/o a chart or memory there just aint an easy way to telltheres alotta numbers on top of that tank. most of em are test dates and man dates...so many ya cant tell even if it did spec the size as a alpha mark it would be hard to find it
GMT+8, 2025-12-25 20:59 , Processed in 0.099628 second(s), 18 queries .
