Question about MIG welder
发表于 2021-8-31 23:37:53 | 显示全部楼层 |阅读模式
Alright so Im new to welding. Im getting the Hobart 125 EZ flux core welder. So when you are welding you have to clap that thing onto the piece of metal your welding, can you touch the metal while welding or will you get electrocuted?
Reply:You can touch the metal, you'll be fine. I have gotten zapped when hot and sweaty and stick welding though“Life is not a journey to the grave with intentions of arriving safely in a pretty well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming ... WOW! What a ride!”
GMT+8, 2025-12-25 19:14 , Processed in 0.075184 second(s), 18 queries .
