Weld Aid Lube-Matic Combo Pak
发表于 2021-8-31 23:37:50 | 显示全部楼层 |阅读模式
Has anyone tried using these lubrication pads on their miller suitcase x-treme 12vs wire feeder? Is there enough room to put these on? It says you can use these on any type of wire except for aluminum and stainless you can only use the red pad. Can you use these on flux-cored wires?
Reply:I just use the dry felt pads on my solid wire and I never use fluxcore. No expert but I wouldn't want oily residue in my liner. I think it would be impossible to clean short of soaking it in solvent. Maybe I'm wrong since I haven't heard of them.                          JMHO,                                    MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I use the black ones. I've never seen the red. Liners are $10-15, so I wouldn't worry about it too much."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-25 19:14 , Processed in 0.103064 second(s), 18 queries .
