Cheap and Simple Grinder Stand
发表于 2021-8-31 23:37:48 | 显示全部楼层 |阅读模式
Hi all, I haven't posted any projects in a while. I mostly just do small repair stuff for myself and friends lately (nothing worth posting). I made two of these stands, one for me and one for my father. He is a retired tool maker and is going to teach me how to use the lathe he gave me, starting with grinding my own tool bits. So of course I needed a grinder for the basement ($38.00 from Harbor Freight with a coupon).The bases are made from big truck brake drums I got for free from a friend. The pipe, channel, and plate I had laying around.The welding was done inside of my garage not in my cluttered and un-raked driveway. I took them outside to wire wheel and paint. They are tig welded with my Miller DialArc HF. I'm much better at MIG but practice my tig welding whenever I get the chance.Sure, I can fix it... I got a welder!!!
Reply:The finished product...Sure, I can fix it... I got a welder!!!
Reply:Nice. I've got a drum just waiting for the same project. Have to find some nice sized pipe though first.
Reply:Looks good! I built a grinder stand from an old truck rim. The problem is the vibration of the grinder makes the stand walk across the floor, I think it's too light.Do you have that problem?
Reply:Originally Posted by CamWLooks good! I built a grinder stand from an old truck rim. The problem is the vibration of the grinder makes the stand walk across the floor, I think it's too light.Do you have that problem?
Reply:Everything should be made as simple as possible but not simpler.  Albert Einstein.
Reply:If those 3 feet happen to have rubber on them, it will almost guarantee that it won't move.Miller 250x & Lincoln V205-TSmith Oxy-Prop torch
Reply:Thanks for the tips, guys.  I have a 3/4 horse grinder and my stand is made from an F-350 rear drum.   Only way to keep it from walking is to put my foot on the drum while I'm grinding.   I'll try what you suggest... Originally Posted by trapperjohnIf you weld three feet (nut, washer, ect.) 120 degrees apart around the base, it will always sit without rocking and could solve your walking problem.
Reply:a truck brake drum weighs about 100 pounds or so, your pickup drum weighs much less....turn it upside down and pour some concrete in it and let it set up.......then weld the washer idea on it.....just a thought....If you see me running for no apparent reason, try to keep up:"Reality" What a concept!Miller Big 40 {1972} vintage, with 150 ft. of 000 leads, old Alaskan pipline welder.
Reply:Good point and advice, thanks... Originally Posted by blumoona truck brake drum weighs about 100 pounds or so, your pickup drum weighs much less....turn it upside down and pour some concrete in it and let it set up.......then weld the washer idea on it.....just a thought....
GMT+8, 2025-12-25 21:00 , Processed in 0.070233 second(s), 18 queries .
