Another ATV utility trailer!
发表于 2021-8-31 23:37:47 | 显示全部楼层 |阅读模式
Here ar esome pictures of the latest ATV utility trailer I fabricated last weekI fabricated all the profiled sides from 18g steel and folded them on my box and pan folder and then seam welded them to 40mm x 40mm SHS.  The hinge system for the mesh sides was my own simple design of a bit of angle with welded to the uprights and a piece of round bar welded to the mesh frames.The trailer size is 5ft long by 3ft3 wide and 3 ft deep.Hope you like what you see!
Reply:Looks like your ready to go into business. Nice job.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthLooks like your ready to go into business. Nice job.
Reply:Looks very nice.  Unfortunately the business that stamp those pieces out of a little lighter material will sell them much cheaper that a quality produced unit can be made for
Reply:Very nice!!!!!!!!!!Dave ReberWadsworth Ohio
Reply:what did you use for axle / hubs?dave
Reply:I dig it!!!  I like the rust brown primer/paint.  Of course I liked the other solid sided trailer too.  What do you do for a tail gate on these?
Reply:A great well thought out project.Primer is OK, but green and yellow would make it tow like a Deere.
Reply:Originally Posted by candersoI dig it!!!  I like the rust brown primer/paint.  Of course I liked the other solid sided trailer too.  What do you do for a tail gate on these?
Reply:Originally Posted by RuffneckDavewhat did you use for axle / hubs?dave
Reply:Originally Posted by akpolarisLooks very nice.  Unfortunately the business that stamp those pieces out of a little lighter material will sell them much cheaper that a quality produced unit can be made for
Reply:Good looking trailer. What do you suppose the weight is on it? Did you consider making the top portion of the bulk head expanded metal (see through) on one? The driver could make visual checks on the contents that way.Last edited by Sandy; 05-21-2011 at 11:55 AM.Reason: spelling"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Originally Posted by gav0994Over here in the UK there are several big companies such as Logic that manufacture similar trailers out of the same guage sheet steel and sell them for around 700 pounds which at the current rate is around 1136 US Dollars.  I can fabricate them up, galvanise them and sell them on for 500 pounds and still make a profit!
Reply:Originally Posted by SandyGood looking trailer. What do you suppose the weight is on it? Did you consider making the top portion of the bulk head expanded metal (see through) on one? The driver could make visual checks on the contents that way.
GMT+8, 2025-12-25 20:59 , Processed in 0.110223 second(s), 18 queries .
