Fittings to make/fix TIG leads available
发表于 2021-8-31 23:37:44 | 显示全部楼层 |阅读模式
Scroll down.http://www.westernenterprises.com/en.../fit_inert.phpSome folks don't know you can shorten TIG cables to repair them, swap ends, etc.  Beats buying a new cable if you can salvage the old one.
Reply:farmall....I think I'll bookmark that for later consideration.  Thank you
Reply:You are welcome. BTW, I wouldn't hesitate to replace TIG hose with (quality) automotive fuel line. TIG cables are really quite simple, but are priced to make a fat profit. P.S.Old TIG cables also make VERY flexy welding stinger leads. They are a bit more prone to pull out of stingers and Tweco connectors, but it's worth it. My pipeliner welding instructor showed me that one.
Reply:We had to do this the other day in a pinch!
GMT+8, 2025-12-25 21:00 , Processed in 0.106563 second(s), 18 queries .
