First time with gas... and a couple questions
发表于 2021-8-31 23:37:44 | 显示全部楼层 |阅读模式
Just got my first tank of gas today. 60cf cylinder w/ an 86/14 mix. Hooked it up as soon as I got home and tested it out. What a difference! (at least to my noob eyes)Settings on the HH140 were 4/40 on 1.5" x 1/8" square tube flowing 20cfm.This is before the gas... (dragging the gun)Here's a couple with the gas... (pushing the gun)And a before and after together...Now the questions...The beads with the gas seem to have a gray coloring to them. Not sure what I was expecting, maybe shinier? Does the color seem right, and is it even important?Also, when I hooked my gauge to the new tank, I was expecting somewhere around 1500psi, but it barely read 500psi. Doesn't that seem low? It is a small tank, but still...And finally, how do the beads look? I'm still learning and only been at this for a couple months.Your help and comments are certainly appreciated!TodHH140HF 4x6 band saw (cut straight right outta the box!)"-Of all the things I've lost... I miss my mind the most."
Reply:You need a little more heat to wet them in and speed up the travel a bit, you're over filling.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by subzeroAlso, when I hooked my gauge to the new tank, I was expecting somewhere around 1500psi, but it barely read 500psi. Doesn't that seem low? It is a small tank, but still...
Reply:Thanks. I'll try a bit hotter and see how that does.I think I'm going to remove the gauge and check everything over again. If all else fails, back to the lws to have it checked out.TodHH140HF 4x6 band saw (cut straight right outta the box!)"-Of all the things I've lost... I miss my mind the most."
Reply:Make sure you didnt do what I did,  I got a lincoln 180 and started with flux, then switched to gas, I was getting a lot of splatter but thought it was normal.  I didnt know that I had to switch the polairty from reverse (the way it came) to normal!   I havent got to try it out yet I lost my adapter to run the 8" spools of wire. But cant wait to try it out now.  Im a Dufus
Reply:Normal polarity... LOL Fluxcore self shield wire (FCAW-S) runs straight polarity, DCENFluxcore gas shield wire (FCAW-G) runs reverse polarity, DCEPSolid wire and gas (MIG, GMAW) runs reverse polarity, DCEPDC Tig (TIG, GTAW) runs straight polarity, DCENStick (SMAW) runs both straight and reverse polarity, depending on the rod.  Most stick is done in reverse polarity, DCEP.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-25 21:01 , Processed in 0.070057 second(s), 18 queries .
