Effects of heat on QT400.
发表于 2021-8-31 23:37:40 | 显示全部楼层 |阅读模式
I have a piece of 1/2 qt400 that I would like to make a rifle gong out of. My question is will cutting it with the torch soften it significantly? Thanks in advance.
Reply:The hardness will likely go up along the edge that you flame cut.  The flame cut will not put enough tempering heat in it to soften the plate.
Reply:Alright. Thank you. Didn't want to end up with an expensive mild steel gong.
GMT+8, 2025-12-25 21:01 , Processed in 0.119067 second(s), 18 queries .
