another gate
发表于 2021-8-31 23:37:39 | 显示全部楼层 |阅读模式
this is what he wanted and he said i did think it would be this good. i get that a lot Attached Images
Reply:Ed, do you mind taking a minute to help me understand the 2" pipe and thread riser?I've not seen that before on a trailer and wondered how it fit in to the trailer's use?thanks,Kevin Morin
Reply:^ i was just about to ask the same thingAdam MMorales Ranch
Reply:Im thinking the pipe is for nerf bars for figure eight trailer racing  : )
Reply:Looks like a filler neck! Maybe it holds some liquid or somethingHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:another good jobGeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:got me wondering now to what are the pipes for 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Hill Billy engineer thunkin'........... spare gas tank. ( read in a Jim Nabors voice...) Why have yer gasoline all in one place when you can distribute the load over the whole trailer! Plus, don't take up hardly no space! Plus, if'in yall chamber the "tank" in sections, and ya get in a wreck,  ya won't not be lossin' all yer gasoline! AND!!!! Yer good to go for hit to past night at the track!!!!!City folks calls it an S-U-V........several use veHicle200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:It's for hidin' the moonshine!
GMT+8, 2025-12-25 21:01 , Processed in 0.100096 second(s), 18 queries .
