查看: 13|回复: 0
Receiver mounted vise.
发表于 2021-8-31 23:37:38 | 显示全部楼层 |阅读模式
Had a spare vise laying around. I found it in the scrap bin at my work, the swivel base was busted so they chucked it. I just made it a fixed base obviously... I was playing with my new torch setup I love it. i cannot believe I have worked this much without a torch! Just getting used to it and I was messing with diff techniques for my welder. I have a hard time with the .045 wire. I knew I should have gone with 035 but its ok. All 1/4" plate and 2" .250 square, still need to smooth up the edges and paint it up.. maybe tomorrow. Attached ImagesHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Oh and I am going to gusset the main plate to the square upright.HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Those are some nice lookin' welds, great work [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Fordman, if you like the OA cutting, try a plasma cutter and you will be in heaven.  My PM 1000 is a beast, ready to cut whatever at a moments notice.  I always seem to run out of stuff to cut with it, but thats OK too.  Thats a good lookin repurpose.  Nothin better than a zero investment tool that does a good job. Those of us on a budget really appreciate ideas like that.BobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:Can't beat a free Wilton vise.  I am sure that was $200-$300 new.  Those welds look great!
Reply:I have got a chinese 40a plasma that actually works pretty good. I have used it a lot, but I really like the versatility of a torch. You can do a lot more with it and it cuts really nice. I was pretty excited about the free wilton! I mean it is a bit used and abused but it still works fine!HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:New guy question:  in your third pic, is the bottom weld on the gusset undercut into the gusset?  Not trying to criticize, I'm learning!  Your answer will be most helpful.
Reply:I dont see any undercut, where are you talking about? At the very end of the gusset? I guess you could call that undercut a bit where I just burned into the end of it... Wouldnt matter thoughHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Originally Posted by morgaj1Can't beat a free Wilton vise.  I am sure that was $200-$300 new.  Those welds look great!
Reply:Originally Posted by fordmanI dont see any undercut, where are you talking about? At the very end of the gusset? I guess you could call that undercut a bit where I just burned into the end of it... Wouldnt matter though
Reply:Originally Posted by weldbeadi bet the ahole that tossed it turned around and ordered a new one..
Reply:Weldbead and Fordman:  thanks for your answers.  My welds have been criticised for being too cold.  Because of your explanations, I better understand and will slow down.Nice save with your vise.   I have two vises rolling around in the shop.  When I need to use one or both I clamp them to the table and fly.  However, that is merely an interim measure as I hope to have time to build a proper mount as you have done here.Thanks again.Dan
Reply:I just can't believe someone threw that vise away just because the swivel base was broken. I usually mount my vises wihout the swivel base anyway. Probably I have been using crappy ones though... Maybe a quality swivel base is plenty strong. Good find!Mikel
Reply:Yeah I always rummage the scrap bins, though theres always a bunch of scrap titanium and stainless I tend to stay away from the expensive stuff. I always get a bunch of hardware and stuff out of the scrap bin too!HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
GMT+8, 2025-12-25 22:50 , Processed in 0.099066 second(s), 18 queries .
