xmt 304 welder
发表于 2021-8-31 23:37:35 | 显示全部楼层 |阅读模式
I just bought an xmt 304  kk038408. hooked up to 220 plug in and both digital gauges come on but no weld output. hooked up black and white wires to positive and green to a ground. what would be the problem. hooked up to single phase also.
Reply:What function do you have selected?Do you have the panel/remote switch in the remote position and no remote plugged in?What do the displays read?Are you sure you're getting 240V on the black and white wire?What leads (stick, tig, wirefeeder) do you have hooked up?Are the volt/amp displays adjustable with the controls?Is your machine CC/CV or CC only?Are you sure it's a 1/3 Phase machine and not a 3 Ph only?Do you have or have you downloaded a copy of your Owner's Manual from the Millerwelds.com site?  Page 24 tells you what the error codes indicate.The more info you provide, the better able we are to help.  There are several members who are very familar with that machine, but none of us are mindreaders.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by jessemead what would be the problem.
Reply:might be a dumb question, but your work piece is grounded to the machine right?
Reply:it is a cc/cv welder.  tells you how to hook up to single phase from looked up owners manual by serial numbers. in stick it tells you both amps and volts.  v sense feeder it tells you volts.  hooked up lead and ground and nothing.  touched my ln-25 input to positive output and touched small clip on feeder ground back to the negative of machine and it would not push wire. the panel/remote switch is on panel
Reply:oh yeah it does not have any display codes
Reply:As Sundown asked...Did you check that you are getting 240v at the receptacle?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Check the power with an adequately fused DMM, the Miller website should have the owners manual and if you dig a little deeper I am pretty sure you will find the "service and troubleshooting manual" for it, which with a series of go no-go tests should confirm advanced problems.
Reply:reads 230 volts at plug in
Reply:what voltage does the tag on the back of the machine say?there are a lot that need higher voltage than 240VG
Reply:Try here for a manual to make sure it is set up right, their are several different models so you may have to go back and get the right manual, congrats on a good machine;http://www.millerwelds.com/om/o2208am_mil.pdf or try post your problem here for a resolution, http://www.fixya.com/search.aspx?st=1&_s=miller+xmt+304or get the right owners manual at;http://www.millerwelds.com/service/ownersmanuals.phpIf none of these help you and you cannot resolve your problem I suggest calling customer service and ordering a service manual, because it seems they want you to buy one or use their service centre or try here for a service manual, if you are a fix it yourself typehttp://www.millerwelds.com/service/r...mentparts.htmlYou should at the very least have a schematic to guide you.Gotta make sure their is distribution of 220V
Reply:did you get this fixed? just went through the exact same problem with my XMT 304... it gets deep quick. lots of detailed tracking .. you will need a quality meter and take extra care as there are high voltages on large capacitors.52, 59 & 66 Lincoln SA200, Tombstone Idealarc 250, Thermal Dynamics Cutmaster 50, Marquette 250 amp mig, Miller 330 A/BP
GMT+8, 2025-12-25 20:59 , Processed in 0.103093 second(s), 18 queries .
