leather jacket cleaning
发表于 2021-8-31 23:37:32 | 显示全部楼层 |阅读模式
I just done with a big project at a fertilizer plant, and before that a feed mill, now all my stuff is nasty as a cheap hooker, and I got Pepsi plant in LA coming up in two weeks. How do you all clean leather jackets? I got the Tillman suede type, and its as funky as a monkey. I just bought new boots and gloves, but even my grinders smells likes a bear's crotch.
Reply:Wash it in cold water and woolite, let it air dry throw it in the dryer on a no heat setting to soften it back up. If its really covered in fertilizer and grain dust wash it in a bucket first then put it in the machine. Use gentle cycle."Liberalism is a mental disorder" Dr. Savage
Reply:I always washed my leathers (sleeves, coat, gloves etc.) in cold water with normal clothes washing powders. Air dried and then sprayed them good with WD-40. I've used the same sleeves and coat for over 30 years. Had to repair the seam in a sleeve once.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Wash it and let it air dry after stuffing it full of balled up news paper.  It'll be stiff when it dries so remove the paper and  put it in a clothes dryer with a pair of clean work boots and tumble it till its soft.  About 30 minutes.Two turn tables and a microphone.
Reply:Originally Posted by PangeaWash it and let it air dry after stuffing it full of balled up news paper.  It'll be stiff when it dries so remove the paper and  put it in a clothes dryer with a pair of clean work boots and tumble it till its soft.  About 30 minutes.
Reply:Take leather jacket to a dry cleaner that does leather items.  Pay the few dollars and then pick up your nice clean leather jacket. Done.  The best laid schemes ... Gang oft agley ...
Reply:I just throw it in with everything else, done. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Put it in a 5-gal bucket full of water, stir it around for a couple minutes, hang up the jacket on a plastic hanger out in the yard in the wind, done and dry again in less than a day.
Reply:Originally Posted by gizzardgutzI always washed my leathers (sleeves, coat, gloves etc.) in cold water with normal clothes washing powders. Air dried and then sprayed them good with WD-40.
Reply:Originally Posted by SuperArcWD-40?  Doesn't that turn you into a candle wick now?
Reply:Originally Posted by NVWWork boots in a dryer? You're either doing this at the laundry mat or you're not married.That or you're setting the OP up.
GMT+8, 2025-12-25 20:59 , Processed in 0.092114 second(s), 18 queries .
