cutting cement lined pipe
发表于 2021-8-31 23:37:31 | 显示全部楼层 |阅读模式
So I have a piece of cement lined pipe that i would like to cut for another project .  How should I cut it ? I tried cutting it once before with a torch and it didn't work just the tip keep getting dirty. I could try a sawzall but it would take a while. would a gas powered cut of saw work if i change the blade. ThanksMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:I'm guessing the pipe is lined on the inside with concrete?-could you beat the crap out of it to break it up?-a hot saw will work, just use water.  It's gonna eat up the blade though, you gotta use a diamond blade and I'm not sure how that's gonna behave with the steel.  -well maybe not, why would you have to cut through the concrete once the pipe is split?Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Cement lined pipe is ductile iron.  Abrasive wheel cutting, using a specialty iron pipe chain breaker, or a chainsaw with a diamond blade are all common ways of cutting this type of pipe.
Reply:I used to cut 4 inch concrete lined with a pipe cutter.Always got a clean edge on both the pipe as well as the concrete.- Tim
Reply:abrasive cut off saw.   My prefered brand of saw is the partner and the 750's have been work horses for me.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I have used an 14" abrasive cut-off saw to cut eight, 4" lally columns with great success.  It is very loud and very dusty.  Best  Bob
Reply:I cut cement lined ductile iron pipe all of the time.Use a gas powered "quickie saw" and ductile iron abrasive blades, they do make a diamond blade for them also.14" saws are what I run, be sure to get quality blades.miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:I had no idea that they used cement in iron pipe.I use used oil field pipe for fences, and it's common to get pipe that has concrete in it.  I figured it was steel pipe, welds ok.  Maybe it's just an oilfield thing, dunno.Anyway.....when cutting pipe with concrete in it you have to almost scarf the cut.  Angle the torch ahead of the cut, and blow the metal away from the cut forward.  The concrete generally will crack enough from the heat to disintegrate when the cut is made, or hit with a hammer.  If you try to point the tip as you usually would, straight down, the molten metal will blow back in your faceWorst pipe is the stuff with the plastic liner in it   Boo coo toxic chemicals when you cut that stuff "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Sorta misleading "angle the torch ahead of the cut".  What I mean is to angle the torch forward, almost paralel, while blowing the metal out of the kerf forward."Any day above ground is a good day"http://www.farmersamm.com/
Reply:A gas powered cut off saw with an abrasive blade is what we use all day long to cut DIP (ductile iron pipe).The cement lining prevents corrosion and doesn't impart a taste to drinking water.  It is a very durable coating and difficult to "beat" off the pipe.  DIP typically has a bituminous coating for corrosion protection on the outside.  The outside coating may need to be cleaned off depending on your proposed use of the pipe.  I am not aware of a chain or snap cutter that works with DIP like you can use with cast iron pipe (CIP).Mortar coated pipe is typically steel and not iron.  We typically use a cement lined mortar coated (CLMC) steel pipe on larger water transmission projects.  CLMC is joined by welding.  The welds are re-coated with mortar after the joint is welded.
Reply:Just use a ductile iron abrasive blade, for some reason the blades made for cutting "green" concrete also work very well on ductile iron, sometimes better than the iron blades.
Reply:wouldn't a pipe chain work pretty good?
Reply:Originally Posted by superwelderwouldn't a pipe chain work pretty good?
Reply:chain type or snap cutter will not work on ""ductile"" iron.miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:Now this is going back a real long time ago (more than 30 years ago) My father did commercial plumbing repairs in schools and stuff like that.  He had a big 4 wheel cutter that he used.  As soon as the metal was cut it seemed easy to fracture the concrete lining with another turn or two of the adjustment.
Reply:After looking at it and thinking of how to cut it and reading your post's. I think ill cut with a torch with a slight angle upward  then break it with a sledge hammer. If that does not work ill borrow a concrete saw and switch out the blade for a abrasive cutting wheel. I think the saw is a partner or something i have used the saw a lot for demo work. thanksMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:Gas powered cut off saw.Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Diamond dip blade or dip abrasive wheel , ci snap cutter will brake itself will not cut. Torch will not work . A exothermic will.
GMT+8, 2025-12-25 20:58 , Processed in 0.068309 second(s), 18 queries .
