Hard hat adapter for fibre metal pipeliner
发表于 2021-8-31 23:37:30 | 显示全部楼层 |阅读模式
I wanted a hard had adapter for my pipeliner hood, so i bought the fibre metal hard hat with the lugs already built in. come to find out pipeliner is too narrow for it to fit onto the hard had. Does anyone know of a hard hat adapter that will work with the fibre metal pipeliner?
Reply:it'll fit but doesnt look like the cap is all the way on the hook?some reason they're made like that.dave
Reply:Originally Posted by RuffneckDaveit'll fit but doesnt look like the cap is all the way on the hook?some reason they're made like that.dave
Reply:Maybe call Fibremetal. I also have the Pipeliner, but do not require a hard hat, yet."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I always liked this type of hard hat adapter. http://www.bettymills.com/shop/produ...referer=searchhttp://www.northerntool.com/shop/too...Fct7QgodXWgAMgDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I have a set, both sides if you want them. Let me know just pay the shipping.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:mine fits same way. guess thats how its made. it'll work fine. chopped top of my hood a touch so it flexes more.
Reply:Originally Posted by CEPI always liked this type of hard hat adapter. http://www.bettymills.com/shop/produ...referer=search[/url]
Reply:Originally Posted by TimmyTIGSure messes with my neck, though.
Reply:Originally Posted by TimmyTIGthat's the one I use when I have to weld somewhere the safety dorks can see me. Sure messes with my neck, though.
Reply:never used one like that. easier to have hooks to switch between the hood and cutting googles.dave
Reply:I have two for the fibre metal hoods.  They are called speed rings.  I hate welding with a hard hat due to the hood sitting TOO close to my face.  I have a very large head and when the hood comes down when using the speed ring, it hits my face and nose.  In fact, I am looking at other options.  At the moment I don't have to use a hardhat.
Reply:You have to push the buttons in so the cups will snap deeper onto the lugs.
Reply:I just noticed that, too. Killroy, you don't have it snapped in all the way.
Reply:not on all the way, but as far as it'll go. i even tried to heat and  shape the hood a little so it would fit better, no luck
Reply:Originally Posted by RuffneckDavenot on all the way, but as far as it'll go. i even tried to heat and  shape the hood a little so it would fit better, no luck
GMT+8, 2025-12-25 20:59 , Processed in 0.111754 second(s), 18 queries .
