trailer brakes
发表于 2021-8-31 23:37:30 | 显示全部楼层 |阅读模式
I recently replace the bearing on my new to me trailer and found that while 3 of the wheels have ok looking brakes(not hooked up at this time)  on just has a bare back plate.  I'm working on getting it fixed up but I've never had a trailer with brakes before and I can't find any part #s on the brake parts and no ID on the axles.  I know it has a square flange for the backing plate and five lug hubs.  It looks like I could measure the hubs  and the bolt pattern on the flange the backing plate is bolted to and just buy the "loaded" backing plate...shoes and springs ready mounted or do I need more info like the axle brand?  also can I replace the brakes on the rear axle and leave the brakes on the front axle disconected until I have more $  to replace those? Attached Images
Reply:The brakes are pretty much universal.  Just be sure to measure the dia of the drum and order brakes to match.  10" is pretty common.  There are two different widths if I remember right.  For example 10"x 1.75" or 10" by 2.25".  I just made up those widths, but they should be close.My name's not Jim....
Reply:Here is a link.http://www.southwestwheel.com/store/...ssemblies.aspxThese prices are $30-$40 cheaper than what I spent the last time.  So I don't think you will find a better deal.My name's not Jim....
Reply:My axles don't require brakes and I didn't know that so thanks for asking and answering. I learned my new thing today now I can go back to sleep.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by BoostinjdmHere is a link.http://www.southwestwheel.com/store/...ssemblies.aspxThese prices are $30-$40 cheaper than what I spent the last time.  So I don't think you will find a better deal.
Reply:Those are 3500 pound, 10 inch brakes (five lugs). They can be bought as complete backing plates that bolt into position and are then connected to the electric brake circuit. The four bolt flange is universal, (or the 5 bolt flange in heavier axles). You can leave one axle without brakes (as an idler axle) as long as your state does not require brakes on all axles, but obviously it handles better with two sets of brakes.Edit; If you reuse old hubs on new backing plates, it is best to turn the drum and armature surfaces.Last edited by tanglediver; 05-28-2011 at 05:05 PM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:plan to do both axles at some point but money is tight; one set of brakes is better than no brakes and taxing the truck brakes.  2 loaded backing plates and a controller is about I can manage right now...after next years tax return it with get a full set of brakes and a new floor.
Reply:The rear axle is recommended for brakes if you have to do one axle or the other. No link provided just relying on prior research
Reply:You can also try Redneck Trailer.com. I have an account w/them. They are very helpful in answering questions too.
GMT+8, 2025-12-25 21:01 , Processed in 0.090092 second(s), 18 queries .
