New to welding - Miller Diversion 165 thoughts?
发表于 2021-8-31 23:37:24 | 显示全部楼层 |阅读模式
Hey, I'm new to welding and wondered if I could get your thoughts on a couple things.I have been wanting to get into TIG welding and I saw that Miller recently came out with the Diversion 165.  It seems to be a more simplified machine at a lower cost.Are there any current users out there? How easy is it to use?Also, I did some research and found that a company called Baker's Gas has the lowest price.  Has anyone heard of them?  Where would you recommend buying from?Here's a link:http://www.bakersgas.com/MIL907005.htmlThanks in advanced for any help!
Reply:Do a search, several threads on the 165.  I have had one about eight months.  I bought it thinking I could fix up an aluminum engine block that had a thrown rod.   Well, the Diversion probably could have welded the block, but I sure couldn't have.  I'm a hobbyist and previously have mig welded and done a little stick welding, but I haven't done enough at any to be very good.  You have to be good to lay down a good looking Tig bead.  I ended up taking some classes and I'm getting better now.  I've used mine for probably close to 30 hours now.   It welds great.  They say 3/16 steel and aluminum is the limit., but I've done 3/8 steel with mine, and thicker than 3/16 aluminum.   I've gone through about 3 pounds of steel rod and about 2 pounds of aluminum just learning - up to 3 1/2 hours at a time , and the machine has never slowed down, gotten too hot or shut down due to duty cycle.  I'm not sure if a professional would like it, but for me it's perfect. It's a simple machine - on/off, AC or DC, and set the amps (metal thinckness) then weld.   It doesn't have a pulser, or any balance control, or any pre or post flow controls, but I haven't needed any of that yet.  If I were buying today, I would consider the Hobart version.  It comes with the footpedal instead of the hand controls.  I bought the footpedal separate for mine - so I have both choices, but that's more money.  I like the features of the hand controls, but I can make a better weld with the foot control.  They also have brought out a Diversion 180 - but I heard it's several hundred dollars more - at that price, there are other options to consider.
GMT+8, 2025-12-25 22:50 , Processed in 0.091055 second(s), 18 queries .
