air comp tank
发表于 2021-8-31 23:37:22 | 显示全部楼层 |阅读模式
does anyone know where to buy replacement air comprewssor tanks ? iv looked and looked with no result. ive got a 8gl twin pontoon style 5.5hp honda puma air compressor. everything else is in great shape.IM NOT GONNA WELD IT TOGETER. just cant find a place that sells just the tanks. kwMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:I've used tanks from a junk semi before.  They even come with mounting bracketsUsed an old propane tank for a vertical mount.  Attached compressor to the ring.I've also used standard red 11 gallon air tanks from the hardware store.  Made my own mount and called it good.(and I've welded an old one back up - but many folks understandably do not want the risk)Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Grainger has compressor tanks in their catalog.Just looked, could have sworn they used to have the wheelbarrow type, but now just the bigger replacements.Last edited by Comp Chassis; 02-06-2013 at 02:29 PM.
Reply:Here you go.http://www.mastertoolrepair.com/whee...le-p-5214.html
Reply:McMaster Carr has them too,
Reply:ouch. i think i will go with a local company round here. they claim to have what i need in stock and delivered to my door in two days for $212.00.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Weld one up yourself!I kid I kid
Reply:no thanks.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Personally, I don't mind making the long skinny tanks for myself, no different than the left over pipe I welded for the air in my shop.  Fill with water and hydro test first naturallyNever had any left over fat pipe to make bigger tanks.I know that many are uncomfortable doing this and I am not telling people they should do anything just cause I doDave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-25 21:01 , Processed in 0.103984 second(s), 18 queries .
