airco super hornet IV
发表于 2021-8-31 23:37:20 | 显示全部楼层 |阅读模式
Hello , new user here, looks like a great source of info.Our diesel welder needs a high current switch and also has all of a sudden been near impossible to start an arc, always sticks , but will weld once it gets going. .Could use some info, the manual is useless for diagnosis.Near portland oregon.ThanksRuss
Reply:Any portable welder repair gurus on here. ??
Reply:A lot of the Airco's were Millers in disguise. Is it similar to a BIG 40 or something. Miller made most of the Airco line from what I have seen. If that is the case you could go to the miller site and down load a manual that is close or at least a good guide. Don't know if the machine has capacitors but that might be a place to look for the sticking on the start. Some of the others with more knowledge will chime in. Best thing you can do is post the serial number and some pictures of the machine and maybe we can track it down    Does it look like these pictures if so I think it is a Miller , just not sure which one.        This one happens to have a 4 cyl gas engine..Last edited by kolot; 01-12-2013 at 11:12 AM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:it looks just like my 1975 miller big 40. same handles same gauges . I bet my face plate would bolt right up. If you changed the face plate and painted it blue I would not be able to tell the 2 apart. my miller has  a f163 red seal. It runs smooth as silk. Im doing some clean up on mine now BTW is those gauges go out you can get new ones at auto zone cheepLast edited by welderinwv; 01-12-2013 at 11:20 AM.
Reply:It is exactly like that one only Perkins powered.
GMT+8, 2025-12-25 21:00 , Processed in 0.111824 second(s), 18 queries .
