Need source for 5/32" TIG parts for 20 Series torch
发表于 2021-8-31 23:37:20 | 显示全部楼层 |阅读模式
Does anyone know where to find collets, collet bodies and/or gas lens collet bodies for a 5/32" diameter tungsten for a Series 20 torch?I have a WeldTec W-20-H torch, which takes the same size parts as a Weldcraft WP20 torch (13N and 45V series parts) but the problem I'm running into is that the biggest tungsten you can use with the Weldcraft is 1/8" diameter whereas the WeldTec goes up to 5/32" diameter.So, when you ask about "collets for 5/32" tungsten for a 20 Series torch," vendors look at you like you have two heads, since Weldcraft offers no such animal.Can anyone help me with a source here?
Reply:1/8" collets, collet bodies and/or gas lens collet bodies and a #22 drill bitwww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:I have my LWS order them for me. I only use Weldtec parts, as they are USA made, and of high temp tellurium copper alloy.  I give them a Weldtec P.N. from this page.http://www.tectorch.com/detail/PDF/R...ts%20sheet.pdfOr call them and ask for sales help. They may have a dealer that can mail order them to you.Telephone (760) 747-3700.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Thank you for the help fellas.
GMT+8, 2025-12-25 22:49 , Processed in 0.129435 second(s), 18 queries .
