Threw together a cart for my O/A setup. I bet no one else can say their cart has 5/8 arp wheel studs... Attached ImagesHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Good looking cart
Reply:Ouch,Those "wheel studs" look like real "ankle biters' to me.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:ah they dont really stick out too far..HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:I like it!Maybe some drag radials with those studs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Ben-Hur Modification...Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by zapsterI like it!Maybe some drag radials with those studs.....zap!
Reply:Not a good design. Looks very user unfriendly. Where is the hose reel/securing brackets? Hard to roll cart around with hose splayed about floor. Also, mounting, hanging the tourch and or attachements to cart begs for damaged ...Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:yeah i was using the cart at that time. I still dont have everything for the torch so I am still deeming it un finished. I roll the hose up and it hangs on the hangar on the side of the cart in the picture. Thanks for your kind words! HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Maybe cope those top pipes to accomodate a horizontal handle as well? If you're up to it, you can add a tray for holding stuff (or sawdust, depending on the environment! Sawmills... ack!)You can wrap the hose around your existing handles which is a skookum way to store it tangle free! Just my two cents. Looks like a pretty sturdy and reliable bottle cart!...Although that chain, I don't know...I think you need something heavier! Last edited by mb_welder; 06-06-2011 at 12:52 AM. |
