I recently took lease on a larger shop space. In a past life the shop was a heavy truck repair/service shop and has 3 in-floor lifts and a large 4 post lift. I bought a 3/4" x 8' x 4.5' steel plate and have mounted atop one of the floor lifts. Adjustable height weld table is great. The plate has mild curvatures. To make it's surface "true" as possible I'm planning to attach a sub-frame made of 3" channel iron. My woe is that the frame will limit clamping abilities. Anyone have ingenious suggestions?Last edited by wagin; 06-05-2011 at 07:31 AM.Reason: deminMiller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:I would set the frame back from the edge 4-6". 3/4" material is stiff enough to easily allow that and that's about as deep as the average clamp can get anyway.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:That lift will make it easier to get heavy stuff on the table, just drop it down as low as it will go and drag/push/pull/roll it on there.HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:Originally Posted by irish fixitI would set the frame back from the edge 4-6". 3/4" material is stiff enough to easily allow that and that's about as deep as the average clamp can get anyway.
Reply:The 4" offset is what I was thinking too. I think I will add casters as well. If I need to move table top, just lower lift and roll. I have an employee that is vertically challenged, he's 5' 4". Yesterday he was working off of the lift table so every time he walked away I would raise the table height a few inches. Eventually he was looking confused when returning to table. After a few hours and a good foot increase in height he figured it out. We thought is was funny, him, not so much. Finally, upon return to table, the height was at 6' and a 3' step ladder was placed infront.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack. |
