My ArcMaster 6500 CoolMaster
发表于 2021-8-31 23:37:16 | 显示全部楼层 |阅读模式
I love this thing.  Water cooling is sooooo damn nice.    The panel adjustment maintains the cooling pump for 1 to 999 seconds, to my preference,  when coming off the pedal.  Trim control on panel adjusts system pressure from 0-35psi.  20 psi delivers 15gal/hr through my CK torch.  The panel displays system pressure and temperature in/out (reads LO under 72F).   Dual 110cfm fans idle at low speed when the pump is off and power up to full speed when the pump is on.  Big copper tube radiator and ultra quiet annular gear pump.  Heavy duty poly reservoir on the back.Last edited by frascati; 05-19-2010 at 11:08 AM.
GMT+8, 2025-12-25 20:59 , Processed in 0.701020 second(s), 18 queries .
