Teflon tape
发表于 2021-8-31 23:37:11 | 显示全部楼层 |阅读模式
Do you guys use it on your TIG torch connections?Sent from my Nexus 7 using Tapatalk HD
Reply:No. It's a tapered fitting.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleNo. It's a tapered fitting.
Reply:huh: why on the Dinse connnector MisterB? I think of Teflon tape as a sealant, though it could also be thought of as an anti-seize I suppose... Seems to me it just reduces the contact area for current transfer in that case, but maybe you've had problems with seizing? My machine lives inside, so it's a mild environment.Miller XMT304 CC/CVBernard TIG coolerSSC foot pedal"It's a poor craftsman who blames his tewls toles TOOLS" (!^$#% keyboard)
Reply:Originally Posted by keithwinshuh: why on the Dinse connnector MisterB? I think of Teflon tape as a sealant, though it could also be thought of as an anti-seize I suppose... Seems to me it just reduces the contact area for current transfer in that case, but maybe you've had problems with seizing? My machine lives inside, so it's a mild environment.
Reply:You don't need it on any of those.....Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Teflon tape is for plumbers not weldersI hate teflon tapewww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Originally Posted by OscarIsn't what you meant to say was that it's not a tapered fitting?  The threads don't actually do the sealing like NPT style fittings which do benefit from Teflon tape;  in most tig torches the rounded nipple on the end is what creates a seal when it butts up against the other mating connector.
Reply:I put a very small amount of Teflon paste on the end tapered portion of the flare fitting.  As mentioned above, the threads don't do the sealing, the flared end does.I can't get my regulator flare to fully seal without it.  I always get a tiny leak.  It's just cheap insurance, you gotta apply a tiny amount and smear along the face of the fitting.  Others may disagree, but it works for me.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:I was told  you don't need tape or dope anywhere on a TIG machine .. and I didn't. Nothing leaked. Had to tighten a few fittings pretty tight, though.
Reply:Originally Posted by Drf255I put a very small amount of Teflon paste on the end tapered portion of the flare fitting.  As mentioned above, the threads don't do the sealing, the flared end does.
GMT+8, 2025-12-25 21:00 , Processed in 0.102035 second(s), 18 queries .
