Cargo rack
发表于 2021-8-31 23:37:02 | 显示全部楼层 |阅读模式
Building these..whatcha think?? Attached Images
Reply:looks good. what is it made of. just a side note i would have put the supports for the top rail on the corners, just how i like the look.
Reply:nice work!
Reply:I like it , Made mine out of steel, weight of the material takes from the overall weight you can carry on it due to hitch limitations so your aluminum (it is aluminum I hope..) is probably a better choice. I like your rail supports, saves material which over the course of a production run can make you or break you. Nice.MLM
GMT+8, 2025-12-25 22:49 , Processed in 0.119179 second(s), 18 queries .
