couple of questions...cooler hose sprung a leak
发表于 2021-8-31 23:36:57 | 显示全部楼层 |阅读模式
My tig water cooler hose sprung a leak yesterday and I am wondering if I need to order Lincoln replacement hoses or is this something I can trip down to the hardware store.  The water cooler is a Lincoln Magnum cooler. The leak occured in the middle between the unit and the torch. Seems to be a pin hole. Unsure due to getting dark but the fluid was sprayed out a few feet from the hose.Also what coolant should I use?  it appears that there is a green coolant in the cooler right now. ThanksRandyLincoln Power Mig 300 with PythonLincoln SquareWave Tig 255 Hypertherm Powermax 45 HH120 w/argon
Reply:Found the leak while my buddy was using my welder. Wrapped some black tape around the pinhole and seems to be sealed up.  RandyLincoln Power Mig 300 with PythonLincoln SquareWave Tig 255 Hypertherm Powermax 45 HH120 w/argon
GMT+8, 2025-12-26 00:52 , Processed in 0.092302 second(s), 18 queries .
