Weld temps'
发表于 2021-8-31 23:36:54 | 显示全部楼层 |阅读模式
Anybody know what temp it takes to get that sulfer-look at the edge of the HAZ when welding mild steel?  Reason i am asking is that as i read the plugs on the race car i see the same yellow-powdery look on the ground strap of the plug - sometimes, on other plugs the ground strap looks like clean steel and i am trying to figure out what the sulfer-look is trying to tell me.Any thoughts is appreciated, thanks oj
Reply:Hello ojh, if I understand your question correctly and you are speaking of a sulfur look, I might consider that you are welding over something that has been galvanized prior to welding or has possibly had the galvanizing ground off prior to welding. The zinc in the galvanizing process will leave a yellowish border along a weld that has been done on galvanized steel along with possible silver hairlike whiskers and a silver/whitish smoke deposit. Hope I understood your questions correctly. Best regards, Allanaevald
Reply:I would guess the coloration on spark plugs is more due to junk from the fuel coating the plug than just the metal discoloring from heat.  Even if the metal is discoloring from heat, you may not be able to use the same color-to-temperature relationship that you have with welding/torch/grinding since there's different chemistry going on inside your engine.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Originally Posted by AndyAI would guess the coloration on spark plugs is more due to junk from the fuel coating the plug than just the metal discoloring from heat.  Even if the metal is discoloring from heat, you may not be able to use the same color-to-temperature relationship that you have with welding/torch/grinding since there's different chemistry going on inside your engine.
GMT+8, 2025-12-25 22:50 , Processed in 0.091419 second(s), 18 queries .
