I just installed a tow system on my vehicle. It has some kind of epoxy paint... looks tough/thick. I have a ~20 gauge chrome bracket for the wiring plug to mount on the hitch. I am afraid of compromising the paint on the hitch for fear of corrosion. I have considered some kind of epoxy adhesive....Otherwise I have a lincoln/century 80 welder could grind and weld it on... But then what would be the best procedure for preventing corrosion?Ideas?
Reply:Could you bolt it to your bumper?Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:No... it is a car...
Reply:drill and bolt/machine screw it to the hitch.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by rubantinNo... it is a car...
Reply:Originally Posted by dumb as a stumpdrill and bolt/machine screw it to the hitch.
Reply:Originally Posted by SquirmyPugYou can bolt a bracket to a car bumper.Or do like Stump said.
Reply:use duct tape..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Duct tape...lol... My 7 year old girl suggested a stapler...
Reply:I am just a little curious--what are you planning on towing with your focus?
Reply:Elephants !!!No...I have one of those small harbor freight fold-up trailers for hauling my trash, leaves, debri and stuff...
Reply:I would put/wire the light harness in the trunk and just run it out and close the lid when you pull your trailer, not like you are using it every day if you are then you really need a truck anyway.Tim Beeker.
Reply:use some self tappers and screw it on, hit it with a little spray paint after and call it good, chances are its powder coated, just make sure the bare metal is protected and hope for the best, its about as good as youll get
Reply:Originally Posted by ironmangquse some self tappers and screw it on, hit it with a little spray paint after and call it good, chances are its powder coated, just make sure the bare metal is protected and hope for the best, its about as good as youll get
Reply:Its just a bracket to hold the plug right? Doesn't need to be really strong.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Welding it will require removing some of the chrome plating on the bracket as well as removing the coating on the hitch tubing.Coat the back of the bracket with silicon and screw the bracket to the hitch.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Use what works, eh? Attached Images"USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:here ugo..just put your bracket anywhere..lol Attached ImagesOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Jb weldLincoln Power Mig 216Lincoln AC/DC-225/125Miller 625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita Baileigh NRA Life Member
Reply:Originally Posted by SuperArcJb weld
Reply:Drill it. Put a little silicone on the screw and in the hole and you will be fine.
Reply:It aint that deep! do anything!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys |
