Bone stock 1968 Sa 200 Redface
发表于 2021-8-31 23:36:50 | 显示全部楼层 |阅读模式
As the title reads i recently found myself to be the owner of a 1968 red face Sa 200, this thing has not been tampered with or upgraded in any way. I bought the welder to use for welding natural gas pipeline. The biggest issue with the welder is it wont idle down. Now I know there are upgrade kits to replace it but I'm a little uncertain if I want to go that route. Also i want to move my gauges to above my front faceplate, what gauges should i purchase and if there are other upgrades that i should look into other then a remote kit?Last edited by 2Tall; 02-11-2013 at 09:22 PM.Reason: I wasn't done.
Reply:Have the same machine, completely stock, love it.  Most guys like the Murphy guages, they have safety features that will shut the machine down if oil pressure drops to low, or temperature goes to high savin the engine. About 60 bucks each."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:WHAT? No Pics! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Is the cotter pin dangling on a chain at the idler or is it pinned making the machine remain in high idle so you can use the grinder?Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Some pictures from the night I brought it home and one after i sandblasted the shell before powder coat. Just waiting to get it back so i can put it back together... cant wait to get it back together! Attached ImagesLast edited by 2Tall; 02-11-2013 at 11:35 PM.
Reply:Second photo shows the R-57 idler pinned for high idle.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Do you know about pinning the idler, has 3 holes, the bottom is the pivot, the middle is the diaphram and the top has a cotter pin that slides through to hold it on high idle, remove the pin and see if it goes to idle, if you know about this , disregard."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:What type of oil should a guy run in these machines?
GMT+8, 2025-12-25 23:00 , Processed in 0.099987 second(s), 18 queries .
