Rego or Stuart Oxygen what kind of torch is this?
发表于 2021-8-31 23:36:47 | 显示全部楼层 |阅读模式
Is this torch usable/safe? Or is it junk?It says Rego and Stuart Oxygen on it.  Other letters I can't make out.(see pic). Attached Images
Reply:That's an oldie. This book is from 1922.http://books.google.com/books?id=m78...0torch&f=falseWeld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:If the valves aren't leaking I would think it's safe to use.  I'd put a set of flash arresters on it but other wise just use it if it were mine.
Reply:Good old torches.  Put on the Flashbacks tho.  Tip looks like it COULD be propane.  Check to make sure.1938 Lincoln SA 600 1973 Lincoln SAE 3001984 Lincoln Sa 250DF800 Ford with 10 ton craneVictor and Harris torches.Rolair compressorSouthbend 13" latheAtlas Mill
GMT+8, 2025-12-26 02:37 , Processed in 0.089324 second(s), 18 queries .
