Aluminum ladder rack
发表于 2021-8-31 23:36:45 | 显示全部楼层 |阅读模式
Just finished this. Turned out nice, the customer loved it. No one in my area makes these so maybe i will sell a bunch. BTW the pics were taken before completion (I hadn't added the removable back bar).  www.performancealuminumfabrication.com
Reply:very nice looking rack ( I left the door open for you guys on that one haha)  is it my eyes, the angle of picture, or is some of the tube oval or rectangular? Looks good
Reply:Really nice looking rack,(It's not often I say that to another guy) Something to be proud of, I hope you sell many more,Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:nice looking cat.
Reply:Very nice
Reply:Nice job how long did it take you to build.
Reply:Nice work.Good use of the oval tube.Just a tip.  We use rustoleum silver to paint the beads on an anodized tower.  Helps prevent the weld from oxidizing.Looks like you're using 4043 filler.  Have you tried the 5356?Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:beautiful work! i too hope you sell many of them. You deserve it. well done!
Reply:That is really sharp, I am curious though what alloy tube that was.  Seems that its not too easy around here to find aluminum tubing in the alloys recommended for bending.
Reply:An aesthetically pleasing artful design superbly welded... superb crafting.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Very nice craftsmanship! You should be able to make a fortune selling those. I hope you do."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:How many hours to build that?  Very nice!"These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:Thanks everyone. I don't know how long it took. WAY TO LONG. because of that i didn't even make any money off this one. It was my first one out of my own garage (two car). I had to calibrate my bender and get used to using it on material that will scratch if you look at it funny. I use a JD model 4 rotary compression bender (not your usual bender for marine fab shops). I get very awesome bends out of it. I also had to build the jig. But now that i have one done im hoping i can get the time down. If i can't build them in 12 hours or less by myself its not worth it (looks easier than it is).I use the rust-oleum aluminum (it is applied on the weld in the above picture). i have never used 5356 on anodized pipe. Should i?Last edited by travisc454; 06-14-2011 at 10:57 AM.www.performancealuminumfabrication.com
Reply:4043 does not anodize it just turns gray, 5356 will anodize and match the parent metal
Reply:looks beautiful. i thoguht i was doing ok on the racks i built. you def. got me beat.
Reply:That is a beautiful looking rack! Very nice work I can see the many hours invested in that.
Reply:Need to figure out how to go national selling those.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
GMT+8, 2025-12-25 22:50 , Processed in 0.113455 second(s), 18 queries .
