blast from the past
发表于 2021-8-31 23:36:43 | 显示全部楼层 |阅读模式
These were given to me by a neighbor....who wants them ?...free  I've never welded using the process and would be interested in hearing from some fellow welders that have.  What kind of results do you get ?-Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:It is used in an oxygen generator.Last edited by Scott Young; 06-02-2010 at 09:20 AM.
Reply:Hey Graham,AFAIK, those oxy pellets were used in a 'special' small oxy-fuel torch set-up.  Without the special torch. I don't know what real use the oxy (generating) pellets would be good for.IIRC, the oxy pellets were for those afraid of or unable to get/use/store an oxygen cylinder.Google reports a lot of mention of those pellets for, umm, 'other' purposes.    The best laid schemes ... Gang oft agley ...
GMT+8, 2025-12-25 22:59 , Processed in 0.250287 second(s), 18 queries .
