How do you weld
发表于 2021-8-31 23:36:41 | 显示全部楼层 |阅读模式
Im still learning but I started out doing cricles and it does great for me but now ive got into doing V's whats betterL&L custom Jeep Bumpers
Reply:Do you have any pics? And tell us what rod, material and welder you are usingUA Local 598
Reply:I use a Miller 251 and I weld 3/16 to 1/2 steel here is one doing cricles L&L custom Jeep Bumpers
Reply:There is no right/wrong better/worse as long as the weld meets the desired specifications.Have we all gone mad?
Reply:On a flat weld like that, I feel it's a good weld if it's properly filled slightly above the plate, with no undercut on the sides.  I'd be pleased with the weld in the pic.You'll refine the whip out of it with time, and be able to have a relatively smooth surface.  I  have a tendancy to massage the puddle on flat welds too.  I like to make sure there's no undercut on the sides."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Your'e hired, or you soon will be.Matt
Reply:That weld is on a angle you just can't see it, ill get a pic today with my V weldL&L custom Jeep Bumpers
Reply:looks good to me, but im just learning with a stickmate.  i have been using 6011's but now im using the 7018 and i love the way it beads up and little to no spatter.  keep up the good looking beads/
Reply:Looks very nice.You'll find that if you do alot of welding, using unnecessary motions, like circles, weaves or other patterns, will tire you out faster than just running straight push or drag stringers.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33You'll find that if you do alot of welding, using unnecessary motions, like circles, weaves or other patterns, will tire you out faster than just running straight push or drag stringers.
Reply:I always liked welding on redbull...you don't even need to move...the vibratory twitches that the caffiene and torine would give would account for mint welds!  "I-I-I-C-c-c-c-c-can't s-s-s-s-st-t-top----vibra-t-t-t--ting!"
GMT+8, 2025-12-26 00:51 , Processed in 0.099037 second(s), 18 queries .
