Lincoln TIG hose repair? (precision 185)
发表于 2021-8-31 23:36:41 | 显示全部楼层 |阅读模式
Just discovered my gas hose/power cable has a leak. grrrr. I haven't yet tried to mess with it, which would involve using a razor blade to slice the outer nylon and explore the innards.  At $90 bucks(part #S25811-1) hopefully somebody has repaired theirs.
Reply:Western Enterprises makes TIG hose end fittings and ferrules. Google is faster than a catalog search.Don't buy the stock power cable. Do determine what ends are on it and buy one less expensive. 90 is high. A complete air cooled torch and cable should be about 80.
Reply:The ends are 3/8' X 24.   Though I'm having trouble figuring what I should be looking for. I see lots of hose and cable, but I don't see a hose that carries the gas and power. Or is it assumed that if it's a TIG cable then the it's a one piece gas AND power cable?   Is this something that would work? (provided I can find out if it has 3/8 x24 fittings)http://store.weldingdepot.com/cgi/we...ml?id=JLVFPDwQ
Reply:Go here, scroll down, play match up, use this reference, any LWS can translate to their part numbers."INERT ARC POWER CABLE NIPPLES & CONNECTOR ASSEMBLIES, BRASS"http://www.westernenterprises.com/en.../fit_inert.php
GMT+8, 2025-12-26 00:50 , Processed in 0.076741 second(s), 18 queries .
