Could somebody please answer this for me..I love welding with 7018 rods..but i have no oven for them so i just leave them in a warm place in the house.For most heavy general work I use 6013s..i make alot of gym equipment and want to use 7018s more often..So my question..Can 7018s still be used for general work even if they are not kept in an oven..Yes there low hydrogen but even if they absorb some moisture from not being in an oven are they still stronger then a new 6013..?or does moisture in the air completly destroy a 7018 rod and make them worthless..Ivan
Reply:Originally Posted by PaddypowerCould somebody please answer this for me..I love welding with 7018 rods..but i have no oven for them so i just leave them in a warm place in the house.For most heavy general work I use 6013s..i make alot of gym equipment and want to use 7018s more often..So my question..Can 7018s still be used for general work even if they are not kept in an oven..Yes there low hydrogen but even if they absorb some moisture from not being in an oven are they still stronger then a new 6013..?or does moisture in the air completly destroy a 7018 rod and make them worthless..Ivan
Reply:So are 7018s that have been kept out in the atmosphere and not stored in an oven still stronger than a fresh 6013?Does anyone here work with 7018s on a daily basis BUT dosnt store them in an oven?
Reply:Originally Posted by PaddypowerSo are 7018s that have been kept out in the atmosphere and not stored in an oven still stronger than a fresh 6013?Does anyone here work with 7018s on a daily basis BUT dosnt store them in an oven?
Reply:So 7018s are still prefectly usable when not kept in an oven...except if the work is to coded standard??
Reply:Originally Posted by PaddypowerSo 7018s are still prefectly usable when not kept in an oven...except if the work is to coded standard??
Reply:I dont use 7014 because they are very hard to come across in ireland..
Reply:Get a sealed plastic tube, it will be fine.Miller bobcat 225g - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Uncooked 7018's that have absorbed moisture will throw porosity in the weld because of the moisture in the rod. Anybody can pass a bend test with wet 7018's just as long as they have a pack of grinding discs and burr bits handy. As far as the strength goes, as long as the weld is sound the strength is their. Stick them in your house oven before welding.
Reply:I've used 7018 without an oven to keep it warm most of my welding life. Moisture isn't a big problem here in the desert, but even after several days of rain/snow/moisture or how ever you want to call it, I stick the rod to the metal and heat the rod up cooking the moisture out, then complete my welds. No they aren't code welds. Yes they have the strength of 7018 w/o compromise.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:There's always the old red-neck rod oven to consider, an old fridge with a light bulb in it.REAL TRUCKS DON'T HAVE SPARK PLUGS
Reply:We use them every day without a oven. Open a fresh can and place them in a rod holder with a ''o''ring seal. Never had problems.
Reply:Here is the 7018 thread http://weldingweb.com/vbb/showthread.php...light=wet+7018Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday. |
