Water tank hatch
发表于 2021-8-31 23:36:37 | 显示全部楼层 |阅读模式
Heres the door I put on the top of my water tank. Its 14x19, there was a opening cut in it 22x14.Its all 3/16 like the tank is. I built the rest of the rig last year. Its 1000 gallons. I still have to mount the ladder on it and paint the whole thing inside and out. I think Ill paint it white. The rims were rusted bad, last year I cut out alot on both rims and welded in new metal. It has a 4in butterfly valve up front, I welded all that on too. I used it alot this year already to water my pumkin patch. I pump it full of pond water. The lid will keep the water from splashing out while I drive. Attached Images
Reply:Heres a picture from last year. Attached Images
GMT+8, 2025-12-26 00:50 , Processed in 0.111277 second(s), 18 queries .
